ratdude747
- Joined
- Sep 30, 2023
- 417
(Using the word "D!ck" to get around the curse filter... as using the actual brand name results in "****"
As part of a "free" 1976 Starcraft Montego 16 Tri-Hull Ski Boat I was gifted, I received several ski tow ropes and a couple pairs of skis.
The ropes I've gotten settled out- a couple are good to use (one of which was attached to a transom cable system that's a bit worn), one was good OK until an animal got in the boat and shredded the foam handle off.
The Skis on the other hand are hard to say:
One pair is a set of D!ck Pope III skis that other than some bubbled labels, seem to be in passable shape:
The other is a set of longer D!ck Pope Jr. skis that were left in the ski locker, which unfortunately had a lake festering underneath it (see thread
) and as a result, the clearcoat and inner glue is shot with some rot starting as well:
Gosh knows how old they are... family owned the boat since it left the marina in 1976 (and I found foam life jackets in the boat as old as 1989
At the moment, I'm not looking to ski (will use a tube and related ropes also included for initial testing)... no rush here. That said, I'd like to know if either set of skis is worth fixing/using, and if fixing, how one would fix such. My gut feeling is that the III's are usable but the Jr's are firewood due to the water damage (especially the rot). But I have no idea what I'm looking at.
