Astroglass 1989 full rebuild
mickyryan
I removed the rubber trim this is not the seal, it's just a rubber trim piece for looks if it was chrome it might look good but I'm not gonna go through trying to find silver paint that looks good and sticks to rubber/plastic
mickyryan
Thought about it but decided I like it without it at all and don't need to worry about it yellowing over time with silvers, keeping it around though i
mickyryan
Got engine mounted so I can continue wiring and rigging, had to clean worksite up a bit (thanks sam) lol the guilt and mess overwhelmed me haha, I'll try getting a few pics later in the day
mickyryan
Was starting wiring got to get that in place before installing gas tank , trying not to backmyself into a corner, it rained allot today so didn't get to do much but got most wires in general vacinity
mickyryan
Made a baitbox light 5 red leds should illuminate bait boxes/livewells just fine,yes I know they make them but this one only has one led and wasn't very bright so I made it better, used crystal clear epoxy to seal them in
mickyryan
Impossible to find 1 gauge lugs locally so I'll make my own picked up some 3/8 copper tubing , I'll post pics when I got ends. CRimped and made :)
Weld lugs at tractor supply.
Most NAPAs
mickyryan
They didn't have any , shelves were bare, nobody locally had anything bigger then 4
mickyryan
It will take a few hours but I did same thing for the trophy so .. luckily I got 2 nice crimping tools for battery wire , and the heat shrink and noalox to weatherproof the crimps :)
kcassells
I had alot of wiring to do on my turtle boat so I bout quite a few tools for that and assorted lugs.
Always seems like the last one you need is missing and holds you up. The copper is a great idea Mick. I know you like making your own do-hickeys.
mickyryan
Well I can't believe I got it but got all my wires and stuff into the outboard... this outboard didn't have a grommet for rigging so I kindaa one :) using a rigid. Vac hose connector since it has a swivel , hardest part was getting everything through it but I did :) the number 1 wires going to starter and ground were a bear to get thru but I feel confident since it's no 1 gauge wire all the way to batteries should handle amperage np
mickyryan
I haven't ran this engine in about 2 yrs so I'm thinking about pulling plugs cranking it and spraying some pb blaster in each cylinder just to make sure it's all lubricated before firing it up , not a outboard guru but figured it couldn't hurt
