Send some hereNother day of rain showers ...
/ clear gel coat
gun that I drilled tip out https://www.harborfreight.com/high-speed-steel-micro-drill-bit-set-30-piece-61526.html to a 2.35mm tip it sprays big flake well and gel coat unthinned, don't set air too high or the flake travels, don't set too low or orange peel gets huge with that tip size on boat if using gel def use duratek
on last coat of clear, the reason to use husky is it has a tip that works well for being driled out the ones at harbor freight just dont have enough meat on tip to be drilled i use throw away paint cups but now harbor freight sells the spectrum stuff thats kinda like the 3m setup
just get proper adaptor for your gun https://www.harborfreight.com/spectrum-paint-system-adapter-57505.html
Victrola8 track or mobile turntable....,LOL
All good amps have vacuum tubesHis radio is great once you let the vacuum tubes warm up
Heck yeah! Any rocker worth his salt knows that!All good amps have vacuum tubes
Mopar fan!Is that boat purple or is the camera getting weird? It looks like plum crazy...
Yeah, I painted a Austin Healy bug eye. We called it the grape. Always messing with it but it was a fun car to drive..Mopar fan!
