Astroglass 1989 full rebuild
mickyryan
Hope everyone in it made it through hurricane ok , call out, roll call :)
mickyryan
Think i want to raise boat on trailer so when I put muffs on I can keep it trim down
briangcc
Back the trailer up on a couple boards to raise everything instead? That way, on shallow launches its not a bugger to launch & retrieve??
mickyryan
Thought about getting ramps and pulling it up on them , but also the boat seems to be touching the fender and side frame so I'd think it's too low in trailer , might not be original trailer but seems like it is but it rides on bunks not even close to you touching rollers in center, another issue I'll probably need to address
kcassells
So sounds like boat is not on trailer.
Put it back on trailer and jack it up to work on.
mickyryan
No it's still on trailer it's just the way it sits , it's perfectly lined up bunks are on Chines but it just sits real low in trailer I'll try to get some pics , I know I know , but it's raining :)
mickyryan
See back is almost scraping the boat , any bounce surely would dug in I'll be correcting that and raising it up today
mickyryan
Boats hanging in air off gantrys while I work on these bunks
mickyryan
Now I can put enginenall the way down and no fear of frame hitting the boat
mickyryan
Getting all the grease and grime off to repaint damn someone was generous with grease lol the steering shaft grease fittings were buried as well as the steering tube
mickyryan
Swear a mouse made a home under the engine lol took a hour to dig out debris but all cleaned up now for sanding all the loose paint from years of spray bombs,I do have a sealer I'll spray before I paint to seal it all up cause I have no idea what kinda paint that was and don't want any conflicts
mickyryan
That lower rubber trim piece im not so sure about , might keep it off but I wanted it to help me keep the decal correct
kcassells
Don't do the rubber with the colors probably fall off.
Looks great from here Sir!
As usual. Tx for the pics.
