wrench 3
- Joined
- Aug 12, 2012
- 2,108
Re: Bearing Replacement First Timer Questions
The coupler on the grease gun uses the grease pressure to augment the spring pressure to lock onto the fitting. A slight hand pressure may be necessary until you get grease pressure on the gun.
Wow! It sounds complicated when you write it down, but it's actually a simple mechanism.
