Hello,
I am new to this forum and to boats. I just picked up a 77 Glastron V184 with a AQ170 (B30) and a 280 outdrive. The u-joints gave out and broke the bell housing and the housing on the upper drive. What is the easiest way to remove the bell housing. Is it possible to remove the transom shield and pull it out from the back or is pulling the motor the only way?
Also the yoke on the motor side is still in there, this should just pull straight out right? I have tried prying it out but I am having no luck. I assume when you would be pulling the upper drive this whole piece just slips out as one assembly, yokes u-joints and all? I did order a new bell housing and upper drive so I really don't need the old one disassembled but I was just curious.
Thanks for the help!
Keith
Keith
