Bellhousing Bushing Kit / Shift Shaft Bushings, shift shaft seal
mguidry629
23-805041A2 is the part number I found on this website:
Bell Housing Parts
I called about 10 dealers in my area and no one has these in stock. I don't think mine was leaking, but I see it's a good idea to replace when you do the shift cable (I'm replacing the shift cable).
I have all the other parts I need to replace the shift cable and I was hoping to get it done this weekend.
Is there another part # that would fit? I assume the Alpha One Gen 2's won't work?
achris
More fish than mountain goat
Re: Bellhousing Bushing Kit / Shift Shaft Bushings, shift shaft seal
If you're working on an MC-1, R, MR or Alpha One, then you have the right part.
Yes.
No and no....
Chris......
mguidry629
Okay, thanks. That's what I figured. I see Sierra sells the same part 18-2622. Any recommendations on whether I should get the Mercruiser part or the Sierra?
achris
Personal choice. I usually choose OEM (If it's an engine parts that GM made... I buy that... Keep Merc out of that equation as much as possible... :D:D)
wrench 3
I've installed a couple of the 18-2622 and have had no complaints. I also used one in my own drive. They fit good and work well. Our local supplier stocks them, so it shouldn't be hard to get.
