Bellows
brodie123
Hi All;
I'm replacing my bellows on my Alpha one for the first time. They are cracked up so replacing with new.
My manual refers to a bellows "spreader". Is this a necessary tool or "with some coaxing" can I get it done?
Thanks!
Black as
Re: Bellows
Use the tool or you will be at it for hours and still wont get it on.
lime4x4
Re: Bellows
i did mine without the tool. I removed the helmet. Installed the u-joint bellow onto the helmet first. Then used the helmet to push onto the transom plate. Then installed the hinge bolts
cr2k
Re: Bellows
Are we talking exhaust or drive bellows?
brodie123
Re: Bellows
actually I'm replacing all of them - new shift cable as well.
My challenge right now is I can't get the bell housing off. I can tell you I have an "old style" bell housing according to my manual in that the shift cable is on the inside of the housing. BUT the hinge pins look to me as a threaded style as I cannot locate any cotter pin for the hinge. I purchased tool C-91-78310 as per my manual - it has a 6 point and a 16? point side. The 16 point side made sense to me - but it very easily slipped - seems undersized? I tried the 6 point side - but also does not seem to be a perfect fit. the hinge pin looks like a 16?? point threaded hinge - but I can't confirm the threads.
HELP!!!
fyi - the boat is mid 80's if it at all helps
