better blue plugs
lucky7
sorry i know this has been posted before but couldnt search it out. has anyone got the part number for the blue mercruiser drain plugs that dont snap so frequently?
Re: better blue plugs
Ayuh,... Take the Blue plugs,+ the Black housings they go into,+ Deep 6 'em....
Replace them with Brass pipe Plugs....
Burtonair01
My question is, I broke one of the blue plugs off while putting it back in. Any ideas on how to get the piece that broke off out?
Brew2
I'd drill a small hole/indent off-center into the plastic then use something like a ice-pick to turn it. If the plastic is soft enough, you might not even need to drill it...just poke the pick in and turn.
Good Luck!
lucky7
i have dug out several with pics, havntt had to resort to ez outs yet, i guess i'll be doing brass next.
Lou C
Agree on the brass plugs...I have the OE ones in my old OMC still after 22 years and they work just fine...I always coat them with a little OMC triple guard grease and they come right out even after salt water use...
Ayuh,... Take the black metal piece Off, so you can get at the plastic piece....
Beat a flatblade screwdriver into it,+ Turn....
Then put in a Brass pipeplug, or even a Stright thru ballvalve or somethin'....
Something that you can Poke through to knock the rust, sand,+ Crap out at winterization time....
