Re: bilge oil
OK, 950 ml sounds better. Check the level by removing the plug from the side of the top gear housing. If none flows out, then get a small cable tie, put a 90 degree bend in it about a inch up and poke it in the hole. This will tell you the exact level of the oil. It's full when it's level with the bottom of the plug hole. I would not consider the yoke seal a DIY. It involves removing the leg (DYI, yes), removing the drive shaft from the housing with the special tool. Then stripping the drive gear and bearings off the yoke and replacing the seal. Reassemble the gear and bearing pack and set the pre-load. If you don't have the manual and the tools don't try it. I have seen a few bearing packs destroyed by people trying to set them up without the right tools. As for the oil, one to ask LubeDude.<br /><br />Chris........
