I have 2 battery setup with a Perko battery switch and a on/off dashboard switch connected thru a float switch. If I turn my perko switch off the bilge will not turn on, if i turn the Perko on I would have to put my dash switch to on position and also have a red indicator light showing all the time, draining my battery. Is this wired wrong? I'm sure I could hot wire the bilge thru the float switch but shouldn't that already be the inherent design? I could also disconnect the red light but i might not recognize the bilge being on. or am i missing something here?
I would expect a Cobalt boat to have the bases covered.
