Tubingluvr
Thread starter- Joined
- Feb 23, 2007
- 426
Originally thought the transom drain plug was leaking (it's one of those cheap plastic ones with the rubber "O" Ring)
Found out that is not the case today.
It would appear to be poor design.....the bilge pump outlet is way too low in the hull (below the rub strip)
Is there a way to plug off the existing outlet so I can put one higher up?
Any suggestions would be appreciated.
