Woodonglass
- Joined
- Dec 29, 2009
- 25,932
If you're using the Bondo Resin, it already has surfacing wax in it. The reasons people don't like the bondo resin are...Expensive, it has wax in it and you never know how long it's been on the shelf and it DOES get old and useless after a while. Another reason is when you're glassing and you lay down a layer and then can't get back to it for a week, The wax has risen to the surface and must be sanded and cleaned off in order for the next layer of glass to adhere properly. The SW is used so the resin will cure faster and be Tack Free. As long as you do all of your layers when the resin is still a bit tacky theres not a problem.
