wewefirex2x
- Joined
- Feb 19, 2007
- 267
My boat is in the shop all torn up. The upholster called me the other day and said he found a soft spot in deck. I went to take a look and it is in front of the bildge over top the fuel tank. I have the stringers marked out. The peice I need to replace is only about 8 inches wide. Since the stringers are so far apart I need to actually replace a 28"x16" peice.
1. He will not cut deck because it is overtop the fuel tank. There is 12 gallons of fuel in a 40 gallon tank. Is it safe to cut floor with fuel in tank? Other than a circ. saw what else could I use i.e grinder.
2. He would like to router 1/4 inch from stringer to stringer and replace with 1/4 inch steel. I do not like that idea.
This is the only place where the wood is bad but he is only allowing me 4 hours to fix. I have to leave the boat in his shop so he can fabricate the rest of the interior.
The foam, stringers and rest of floor are completely dry. I have accessed them from holes that are in the deck.
Please Help!!! This is my first deck repair
