boat not running on pad
timmee73
I pulled the motor to change the t/t. When i replaced I am not sure if i bolted it back to the same holes. I am wondering if I should raise the motor or lower it. It is a 115 merc 1991 and a1991 procraft boat. When going full throttle the water is spraying out at the driver console.
crb478
Re: boat not running on pad
raise it as high as you can until you get cavitation then you may need to go back down a hole. The less drag you have the faster you will go.
Bob_VT
Do you have a water pressure gauge? Temperature gauge? Properly running "on the pad" has a great deal to do with the proper prop. Consider posting all the proper information in the prop section and follow Dhadleys advice to the letter ;)
