I have a 99 Seaswirl Striper Wa with a factory Gil Bracket. On that bracket are two 2008 Honda BF150's. I am looking into a prop that has been reccommended.. 4-blade 14-5/8 x 16 Stainless
Would this work? What do you reccommend?
1) Performance issue you are trying to correct.
40mph max speed, cruise at 25mph.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
Honda aluminum
3) Current prop diameter and pitch (required).
15.25 x 15 aluminum 3-blade ONE IS COUNTER ROTATING
4) Wide open throttle RPM and speed with an average load (very helpful)
hitting 6400rpms VERY easy.
5) Engine/drive make, model, year, and HP
2008-Honda BF150 x 2
6) Boat make model, year, length and weight
1999 Seaswirl Striper Walkaround, 6,000lbs
1. Year, make and model of boat
99 seaswirl striper 2600wa HT with factory Gil bracket
2. Length, width and base weight of boat, look for boat decal on back of boat
24ft, 102", 4000lb without motor, 5000lb with motors
2a.What is the maximum recommended HP for your boat
300hp
3. Number of people and gallons of gas normally on boat
2-3 adults...134 gallons of gas
4. What do you use the boat for
100% - fishing
5. Is it a Deep Vee and if so how many degrees of Deadrise
20 degrees deadrise
6. Year, manufacturer and model of motor
2008 Hoinda BF150 x 2 ONE IS COUNTER ROTATING
7. HP and gear ratio of motor IMPORTANT
150hp, 2:14 Gear Ratio x 2
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
5500 RPM is at rated 150hp
9. Anti-ventilation Plate height above the bottom of the transom of boat if it is an outboard in inches, use a straight edge or a board under the keel and sticking out to the anti ventilation plate for a reference, and take about 4 pictures for us to see.
4" above
10. Is it a bass boat or does it have a pad bottom
no
11. Does it have a hydrafoil, dolefin or trim tabs
will have trim tabs--not currently
12. Manufacturer, model, diameter, pitch, number of blades and whether SS or aluminum props.
IMPORTANT
Honda, 15.5? diameter, 15 pitch, 3 blades, aluminium
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for less than $ 50
RPM ___________ Speed (GPS)___________ No. of people ____________ Gal. Gas ________
WOT 6400rpm @ 35.5mph, 1 people, 134 gallons
14. Are you at sea level or a higher elevation, give us the elevation in feet __________
sea level
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way by only using the control on the console, checked compression, looked at the plugs and checked spark, is the bottom of the boat clean and barnacle free, and have you checked the Tachometer against a mechanics tach, all of the foregoing could be the reason your prop is not attaining full RPM.
Everything ok.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop.
Came with boat, unknown history, hits 6400 EASY!!!! (motors at 28hrs each)
17. Does the prop show any damage that you can see
no
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
I want low end torque (hole shot) and good fuel economy. @ Say 3800 RPMs?
Honda aluminum
300hp
100% - fishing
20 degrees deadrise
4" above
no
IMPORTANT
sea level
Everything ok.
no
