boat pulls to the right
bretto
If I am thinking right, wouldn't I adjust the trim tab to the left a bit? This is on an outboard if it matters. And what is this I hear about torque steer (if that is the term), what way does a boat normally want to pull.
Brett
bretto
Re: boat pulls to the right
Just did a search and I think I now understand that I need to adjust the tab in the direction of the pull. This will push the prop the direction it needs to go, I was thinking it would push the boat.
tashasdaddy
boat pulls right back of tab to the right, viceversa.
Jdeagro
iboats.com Partner
Torque Steering is cause by the prop rotation (clock wise) and the boat "wants" to lean an steer in the oposite direction (left / port).
It is usually caused by running with too much bow pressure (down). This is usually from motor trim (too far down) or a hydrofoil.
Steering to the right / starboard is most likely from an incorrect adjsutment of the steering tab above the prop.
