I'm looking at a 18 ft. runabout bowrider for just cruising local lakes...It has a 3.0 Mercruiser. What are your thoughts about the 3.0? will that be enough horses for that rig, how fast should I expect the boat to go? Thanks
It'll be great for cruising local lakes with a couple of people, probably disappointing compared to something with a 4.3L V6 if you are interested in any kind of watersports with several people in the boat. Expect a MAXIMUM speed in the low 30's. Only thing I didn't like about mine was that cruise speeds (mid-20's) are so close to max speed that it always felt like the equivalent of cruising down the freeway at 70 MPH in your car in second gear ....
I have a 1990 18ft Maxum open bow with a 3.0l mercruiser 135hp and alpha 1 outdrive with a Mercury alpha 4 p/n 48-834854A45 (14x20) 4 blade prop and my max speed is 42 to 45 mhp at 4800 rpms full tank of fuel and 2 people in the boat.
Take what people claim with a grain of salt. Do your own research on Boattest.com, etc.
45 MPH at 4800 RPM with a 20" pitch prop works out to 2% prop slip. Theoretical max speed with 0 slip is 46 MPH. Just think, if you took out a couple of hundred pounds of gas and another couple of hundred pounds in the extra person and gear in the boat, you would be able to go faster than the prop could push you! Probably hard to find one of those magic boats like yours.
Great shape for $6000...does that sound right?
NO!! That sounds ridiculously high for a 15+ year old boat with the base motor. $3k maybe if it's immaculate.
I agree..... just because a dealer can get it doesn't mean it's a good buyNO!! That sounds ridiculously high for a 15+ year old boat with the base motor. $3k maybe if it's immaculate.
