boating question please thank you
junior1113
just bought a 20' cc hydrasport it has trim tabs and also has a plainer wing on the 200hp motor is this needed for anything i thought it slowed the boats top end thanx
ondarvr
Re: boating question please thank you
Do a search and you'll find more details, but take it off, you probably don't need it.
capt sam
Take it off, if it helps great, if not throw it back on.
junior1113
ill take it off trim tabs do the samething but more effiecently should i pick up a couple mph???
Bob_VT
Trim tabs are GOOD ....leave them on. The fin on the outboard IMO are not worth it but you can read and find that out.
The trim tabs are better.
grego
Only my opinion?-- The engine fins help to get you up on plane faster with "less drag" than trim tabs, at slower speeds. Ounce on plane the trim tabs come into play to stablize boat. "I say leave them on.;) " Just read link! the skipping they were talking about "in choppy water turns" are directly related to trim tabs! If in a turn and the trim tab loses contact with water you tend to skip away from direction of turn. The engine fins "always" have contact with water and therefore,guides the boat into a smoother turn and helps keep the trim tab in contact with the water. My .02
ondarvr
Did you read the link?
tashasdaddy
tabs and foils are not to be used together. imho, foils are the worse thing you can put on a boat, other than a 14 ft tinny.
NSBCraig
Get rid of the foil.
For whoever said something about tabs handling bad all I can say is ....um No.
Lose the foil.
