stephentyler20
- Joined
- Apr 13, 2008
- 117
Hi guys - been a while since I've posted on here! I've messed around with a couple small fiberglass projects in the past, but never repairs. I'm hoping in the next few weeks while I have some time I can make this better.
I was forced to dock my 21' Cuddy bow into a dock for the past few summers. Despite numerous attempts using buoys and cushions trying to soften the blows, inevitably the boat ran up against the dock, and wore away at the glass. It got... pretty bad. I'm annoyed to say the least.
Below are photos of the damage... From what I can tell there's two areas of damage. First, the area UNDER the bow eye has some erosion down to the fiberglass. From what I gather, I should be able just to grind this away, lay up some glass on this, add some filler and paint or gelcoat.
The area I'm worried about is the bow eye. What happened is, the eye itself took a lot of trauma, bouncing off the dock with the weight of the boat. As a result, it widened out the holes that it sits in. I don't really know how to approach fixing this... For starters, I am definitely going to add a hardwood backing on the inside that I can bolt this into, and fiberglass that in. Should I also grind out the whole area, and make a new surface that I can drill new holes into?
Thanks for the help in advance!
