Bravo 3 input shaft removal.....questions
jonoman69
I have a 1997 Mariah z255 shabah with a bravo 3. I noticed I started going through gear oil but no water was entering the drive, last time I have the boat out the gear oil got in the bilge. In doing some research I was just wondering about the input shaft removal, I cant seem to find out if it is necessary to remove the covers off the drive and the shifting mechanism before I remove the input shaft, or can I just simply remove the yoke assembly without taking apart anything else on the drive?
Bt Doctur
from manual 11 it looks like the same procedure as the Alpha. loosen carrier nut with the spanner and pull straight out.
