MightyEsquilax
- Joined
- Jul 15, 2012
- 32
I've got a 1996 Bravo 3 with a 7.4. I replaced the lower shift cable this season because the shielding was chewed up from an improper installation. I performed all the cable adjustments using the proper Mercruiser adjustment tools. Up until today the boat has always shifted reliably into fwd and rev with no issues.
The symptom I'm seeing is clean shifting into rev with no hesitation but a 2-4 second delay upon putting the shifter into fwd detent. If I put a little throttle on during the 2-4 delay she'll get into gear quicker but with a thump...
I ran the boat on muffs in the driveway and interestingly enough I get no noticeable delay shifting into fwd gear. The fluid level is fine but I'll drain it just in case to check for any thing burnt or broke. I will double check the cable adjustments again also. I don't see any other performance issues other than the delayed fwd shift.
I've read a couple of things on the forum that indicate it could be a "bent shift fork" or "cone clutch". Any place else I should look for a problem? If it is a shift fork or cone clutch am I better replacing the upper gear box or do I dare dive into the existing and try replacing myself?
