Bravo One impeller help!!!!
Dawg'sLife93
I'm having impeller trouble. I changed it with a Quicksilver kit, but when I start the boat on Muffs, no water comes out the bottom of the drive and the spray off the muffs doesn't change whether engine is on or off. I have great water pressure to the muffs.
PLease help and give some ideas what to check. Thanks in advance!
Eng sn- 0C769578
Drive sn- 0C884355
Transom sn- 0D312529
TilliamWe
Banned
Re: Bravo One impeller help!!!!
Does any water come out the exhaust relief ports up at the transom?
TilliamWe
Banned
Did you accidently reverse the input and output hoses on the pump? (It happens)
Dawg'sLife93
Thats what I meant by bottom of the drive, I just couldn't remember the correct term for it. No, Nothing out the relief.
I might have, I'm about to go recheck things in just a min, I was a little miffed and needed to cool off, before I set the whole dang the on fire. LOL
Thanks for the tip.
Dawg'sLife93
Update:
I had the hoses reversed, smoked the impeller, another 80 bucks spent and another new kit on the way.
TilliamWe
Banned
Why did you spend $80 on an entire kit? Why not just $27ish on the impeller?
Don S
He probably has a plastic housing, and they get melted too when run dry.
Dawg'sLife93
Yep, I just took the edges off the impeller, but rather be safe than sorry. Rather 80.00 than 3500.00for a new engine.
Dawg'sLife93
Anybody got a hose routing diagram for a bravo one seawater pump? I don't want to make the same mistake I did already. Thanks in advance!
Don S
attachment.php
Dawg'sLife93
Thank you! I got it together and working great! Real love how ya'll are willing to help. Thanks again guys!!!
