Broken Starter Bolt trying to Switch to inline Motor. (Success, Chainsaw sharpening dremel bits helped get starter bolt out.)
Hello all,
I recently puchasd a boat only to find out the second trip in that the start was being helld on by one bolt and the other bolt was sheared off inside the block. I pulled the engine and tried for almost the whole day to get that bolt out to no avail. Gave up when the easy out snapped inside the hold I drilled in the bolt.
This is a 1998 0C 4.3 Mercruiser. The starter that was on there (863007A1) was the staggered bolt kind so I'm assuming my flywheel is 168 tooth. Before I completly have to switch everthing to a new block I thought I could switch to the other style starter with the in line bolt pattern.
I've identified this marine starter (8M0090697) which is in line. Will I need to change my fly wheel/flex plate to the 153 tooth version to use this starter?
Thanks,
Brian
Hello all,
Thanks,
Brian
