Landscaping Wiz 808
- Joined
- Jun 29, 2008
- 498
1986 Johnson 9.9hp - model #CJ10RCDB
Well, I snuck out of work early yesterday to go fishing.
Caught a few good bass and then when I went to fire the motor up I broke the starter rope. i was able to get it running by wrapping my back-up rope around the flywheel, but before I go ahead and order repair parts (iboats has everything!) I want to make sure I get everything I need.
The recoil spring seems to have lost a lot of tension, can I rewind it or do I need to buy a new one ($20.99)? Here's a picture:
I'll probably replace the starter gear as the plastic is a little chewed up where it engages the flywheel.
While I'm in there I'm going to rebuild the carburetor again and I'm considering changing the fuel lines to "ethanol friendly" lines. Should I replace both the large 1/2" hose and the smaller 3/8" hose? Can I use small zip ties in place of the original plastic clamps?
All of this may seem like overkill, but I'm taking this motor with me on vacation at the end of the month and I'll be running the boat with my Nephew in it, so I'm trying to make it as reliable as possible. Thanks in advance.
BOB
BOB
