Bronlonius
- Joined
- Oct 21, 2012
- 145
Re: Buick Le Sabre tow vehicle
I have towed with smaller cars, I would not be worried about the engine being underpowered. The main problems are that the car is FWD, and that it's geared for low rpms on the highway, vs. more torque at low speeds. The transmission, if it's an automatic, will always be the weak link.
there are 3 things that are important:
1. If it's an auto trans, dont tow in overdrive. Change the fluid often, and make sure it's being flushed so that all 10-12qts of fluid is replaced(draining the pan where you change the filter only removes about 1/3 of the fluid).
2. If it's an auto trans, install an inline cooler. even if you don't have a cooler, let the car run in neutral for a few minutes after towing so that the transmission fluid cools itself off. Shutting off a car with hot transmission fluid can burn the clutches.
3. Balancing the trailer so that it has the correct amount of tongue weight is very important. You need enough to keep the trailer from swaying, but not too much, otherwise the trailer will push on the back of the car too much and you won't have traction coming out of the water.
Usually, "performance" cars will have beefier components to take the abuse of a more powerful engine, and be geared lower. My current tow vehicle is a volvo 850 with a turbo 2.3l engine, and it has no problems towing or pulling my boat out of the water.
