Building sparkplug wire with boots
mtcabinfever
I purchased new coils with wires I have to assembly. I am having trouble putting wires together. Do I put end on wire then add boot or put wire through boot then put on end? Boot seem very tight just getting wire through not to mention with end on it. Any advice? Id there an easy way?
retiredfornow
Re: Building sparkplug wire with boots
FWIW, I think put the end on the wire and push it into the boot, with some soapy water to help it along.
nwcove
there is an excellent video on utube of that exact process, google it. ( i will have a look and post the link if you dont find it)
sludgeguy68
I cut a bit of insulation off the end of the wire and fray out the individual copper pieces so it has more contact with the metal piece... make sure the frayed ends are short and don't extend past the diameter of the wire. Push the metal pin into the center of the wire and push it tight against the frayed wire. Then push that metal end into the boot.
Getting it into the boot can be a bit tough; some rubbing alcohol might help slide it on - it evaporates after the boot is on without leaving a residue.
kfa4303
Banned
You can also use 90 degree crimp on connectors and boots. They can also be soldered on as well. You simply expose about 1/4"-1/2" of wire from the boot end, fold it back on itself, crimp on the connector, slide on the boot and voila! you're done. Here's aid of a guy soldering his on, but you don't have to do that step, if you don't want to.
http://www.youtube.com/watch?v=QW5wEnUeEew&feature=BFa&list=UUqtXoVOxjtEKjjTKj0cFydg&lf=plcp
nwcove
the vid kfa posted is the one i mentioned. and soapy water will work better than a dab of spit ! lol
kfa4303
Banned
I'm convinced spit is the single most powerful liquid ever crated. It helps you eat, build you spark lug wires and it will remove any and all stains from a kids face. Just ask a mom :)
nwcove
in my neck of the woods , alot of moms chew tobacco, so the stains that get removed by "mom spit" , get replaced!!! ;)
Silvertip
The very best spark plug boots are made by NGK. These are phenolic, can be had with or without resistors, and simple to assemble on the wire. They will last forever and are not expensive. These are similar to those used on motorcycles and snowmobiles.
wired247
90 degree angle connectors are $0.48 at Napa. Boots are $2 each. I use a MSD wire crimping tool. It was $5 or so and you use it with your vise. Strip back a bit of the insulation and fold the wire back. Crimp the end on and shove the crimped end into the boot. Whole process takes about a minute .
akdiesel
I use dielectric grease in the boot and a little on the wire and they go right on. BRP recommends dielectric grease in the boot anyways to keep it from "bonding" with the ceramic of the spark plug, so that is already taken care of when it goes together.
Salfal
I have just finished reworking the ignition system on my Evinrude 15922 and with the stainless spring connectors.I warmed my boots over a infared shop heater till they became soft and pliable then pushed the wire and connector right in.
kfa4303
Banned
Ditto on NAPA. Other folks have had mixed results with them, but they're one of the few places in my neck of the woods that has copper core s'plug wire in house, and they'll order Sierra parts overnight for FREE. They have 5200, motor and gear oil and a few other basic boating supplies too.
toddschubert
WD 40 works well and DO NOT SOLDER WIRE different metals will promote corrosion
