Gonefishing85
Thread starter- Joined
- Jun 25, 2016
- 90
Yes, however probably a vertical out
Like this?
your boat, do what you want. my only other reference for OMC HX's is the other thread and old catalogs. Every OMG V8 HX installation I have ever come across except this thread and the other OMC have the HX across the front of the engine, a large expansion tank, two nipples for the manifolds (one for each) and a straight up T-housing.
About any SBC thermostat housing can be used, its just routing hoses and you can figure out how it will work. I would try to keep the hoses no higher then the HX cap or lower to keep air pocket from forming.
Your intake should have a plug which can be removed and a sensor installed.
The return line is most critical so figure if you have a plug on the circulating water pump or will need to put a Tee in the return hose.
As before the supply can come from the intake thermostat area of the block drain
