Can I add a telltaleto a 15 hp Rude?
dimock44
I found a 1975 15 hp rude with an electric start. It seems to have no telltale and what I need to know is would drilling and tapping the water jacket over the heads for place to put a hose barb for a pee tube be ok? Would you tap it at the top, bottom or middle? Is there a better place? Or is this possible?
iwombat
Re: Can I add a telltaleto a 15 hp Rude?
All possible. I think on that motor, I'd be more inclined to go in at the top of the exhaust cover though.
dimock44
Thanks Iwombat.
I found the exhaust cover. It's got the terminal strip and rectifier in it. Right? Why do you prefer that over the cover the head? I'm not questioning your advise , I just would like to know the reason. My thoughts would be to see when the T-stat open?
ezeke
LeeRoy Wisner has some fairly detailed instructions for that on his website: http://www.sschapterpsa.com/ramblings/Johnson 9.9_15.htm
dimock44
Thanks ezeke! Please take a look at the FAQ on fuel pumps Sticky.I posted a Question for you There
iwombat
The job of a tell-tale is to siphon water BEFORE the t-stats. That way you can see if your water pump is working. Unless there's a reason to go further downstream in the water flow (like on a crossflow V4 where #1 has a tendency to get airbubbles) I prefer to place the siphon as close to the water pump as possible. Plus, you mess up the exhaust cover, you can go get a new one.
iwombat
Hey, Murphy's Law definitely applies.
patrick4266
I did a tell tale on my 1972 85 hp rude and it was probaly the easiest thing I ever did on the motor.
ezeke
When it comes to outboard motors, Murphy was an optimist. :)
dimock44
Just wanted to say thanks again guys. I followed Leroy Wisners instructions and all went well. Feel better being able to see the water.
