can i swap cd boxes
yohuallin
ok so the 85hp is a 3 cyl, with 2 cd boxes, each one of them with connections for 2 cyl, since the motor is a 3 cyl one feeder is not being used, and my cd box that feeds 2 cyl one half is not working properly, so can i swap it with the one that is only using one side?
maxum247
Re: can i swap cd boxes
If you have Prestolite Igniton (blue modules and coils) you can swap them.
Your manual should give instructions on how to wire the CD modules!
Say #1 cylinder is firing and #2 cylinder isn't, move that module and wiring to #3 module position useing the working side of the module for #3 leaveing the (nonworking) side as though it were to hook to #4 as the spare and move the module from #3 to the #1-2 positon now #1-#2 should fire as well as #3.
You'll need to move the wiring that goes with each module so take pictures and keep your manual handy so things get wired back correctly!
Good Luck!
