Can move outdrive up and down by hand
Horst007
I have a 1971 mercruiser and can move the outdrive up and down by hand. I would like to know where to start with this so that I dont do a bunch of unneccessary work. Please help!!!
gshldon
Re: Can move outdrive up and down by hand
need some more info on the problems you are having
Phantom_II
How's the trim pump fluid level?
danond
You're out of hydraulic trim fluid, trim pump is toast, trim cylinders are toast.
It's a pretty simple system. It's one or more of the above three.
Horst007
Trim fluid is full, no cylinders present it is more of a gear drive type of tilt system. I have attached pictures.
P 0 P E Y E
You said merc....pics are OMC
Omc harder to fix
danond
Horst - just confirming. If the pictures are the drive you have, that is not a Merc. It is an OMC drive. Very, very different.
Horst007
OMC not mercruiser that would be why I cant find a picture of it in my manual... I am such a noob... Thanks guys I will get a new manual and trudge on...
Ayuh,... Search OMC Stringer drive....
