Can the base of engine work? Two to bolts under engine are rusted and can
liusigou
It is a little bit difficult to code start my engine and the temperature is about 5 degree in the lake.
Do you also have this kind of issue?
Press the throttle only button, 1 full pump of throttle to set choke and prime the carb, then pull back to about 1/4 throttle
Turn the key. Once it fires, pull back to about 1500 RPM
Scott06
Exactly was going to say how are you starting it and is the choke operating properly. Marine carbs don't have a fast idle cam like cars so you have to do that with the throttle lever
liusigou
Thank Scott06 and Scott Danforth. It works better with your advice.
Step 1:press button and a few times of full pump gas
Step 2: pull back to 1/4 throttle
Step 3:Turn the key
Step 4:pull it back to 1500RPM
Step 5 pull it to neturel after it run smoothly.
Ready to go
Thank you
liusigou
Yesterday I was in the lake and was very difficult to cold start my engine even I followed your guy's steps. But it backs to normal after the engine is warm.
liusigou
I have tried to start my engine in driveway and I found it worked fine if I pull the throttle at the position of not at 1/4 but nearly full position.
Ayuh,..... Whatever works,..?? Use it,.....
liusigou
I bought one water pump impeller of Chrysler 115 HP outboard about 7 year ago. The engine of Chrysler 115hp (year is 1978) was gone.
Can it fit mercruisier 2.5L year is 1989?
liusigou
How can I know if the impeller is broken while running in the lake. At that time I cannot see the water flowing from engine too.
Scott06
keep an eye on temp gauge get used to where it is. if water flow stops engine will get hot immediately. on my old boat with 140 deg thermostat used to at hot idle run about 150 normally temps started creeping up to 160 ish just before impeller died, then it got real hot real fast...
get used to scanning the gauges.
New boat with 160 thermostat runs 170 or so...
flashback
There are flow meters available that have an alarm on them. Don't know anything about them but might be handy for when the ice bag gets caught on the intake..
liusigou
How to start my engine without the ignition key? Can I provide the 12V between the pisition of 1 and 2 in the attached picture?
that will turn the motor over. to actually start it, you need power to the coil
liusigou
My engine cannot start after I replaced the gasket the distributor. It worked very good before I did this job. What is the next?
