Can the base of engine work? Two to bolts under engine are rusted and can
liusigou
How can I turn the engine manually? I found a video which show rotate the engine manually.
it is
What kind of tools is it?
liusigou
What kind of tool should I apply to rotate my engine? Thank you
todhunter
Canoeist
It looks like he's just using a steel bar between two of the bolt heads on the water pump pulley. If you don't want to do that, I'd recommend using something like the ProForm Crankshaft turning tool. It bolts to the harmonic balancer and gives you a hex or square drive so you can safely turn the engine over.
Scott06
Take the spark plugs out you will be able to turn it by hand on the pulley.
You need to go through retiming your engine with a timing light. Need to bring engine to TDC on compression stroke (both valves closed) on #1 cylinder. Turn distributor so that rotor points to number one post on cap. that should get you in the ballpark to start the engine if done correctly. Once running use a timing light to get it set. Timing is usually on sticker on engine or flame arrestor cover
Do you know what ignition system you have on it - if you have points it is fairly simple if you have a later Delco EST you need to put it in base mode to set the timing.
You can find some youtube videos on this
liusigou
Thank you. I have rotated the engine to the 0 point.
liusigou
it works after I set the timing back accrording to the video of
. Thank you everyone
Ayuh,...... That zero could be Tdc, compression, or Tdc exhaust, so you have to be Sure it's Tdc on the compression stroke, not the exhaust stroke,.....
Otherwise, it won't start, nor run,....
liusigou
How can I turn on my motor if I miss my key on the lake? I watched video on the youtube and it showed that I should connect the redline pole and yellow line pole by a wire then motor will start.
liusigou
You're using non-genuine bellows. That is why you're having trouble putting them on. I used GLM bellows ONCE, never ever again. I always install anything made of rubber as genuine Merc. Bellows and impellers... Always genuine.
Hi Archris,
I am trying to buy genuine bellows for mercruiser alpha one and gen I.
Could you please suggest which product are genuine? Could you please give me a link? Normally I prefer shopping in Amazon.ca.
Thank you
Grub54891
Hi Archris,
Thank you
Quicksilver parts are the real thing. Anything else is not. You pay more but it’s better than doing it twice.
Hi Archris,
Thank you
Chris hasn't been here in years
You will only get Mercruiser parts from your dealer or a dealer with an on-line presence. Not Amazon
liusigou
The power tilt cannot work correctly. It can let outdrive down but cannot pull the outdrive up. Which part is bad?
liusigou
Anyone can help me check again this gimbal bearing had hole or not? At that time I could not find a hole for grease filling, now I tried to fill the grease. and attached file is what I saw. You can click the link to see the detail of the gimbal bearing I bought 2 years ago. Maybe I have to pull it out and check it again to ensure I install the gimbal bearing correctly.
Scott06
liusigou
yes Quicksilver is OEM and the bearing will be sealed. Should have come with a pipe plug to replace the grease nipple in the transom housing
Quicksilver is same parts as Mercury/Mercruiser , just different branding so they can sell them outside of their dealer network.
Should I do any maintain for the sealed bearing. I tried to turn it by my hand and felt it is not very smoothy while turning
