Can the base of engine work? Two to bolts under engine are rusted and can
Grub54891
If it doesn’t turn in any direction you have the wrong bearing. I looked back at your pics, it does look like the correct bearing. Try this: put the alignment bar in, but not engaged wi the coupler. Lift up on the bar. I bet it moves the bearing. Some are rather stiff, but do “ gimbal “
liusigou
Yes. It can turn in any direction.
liusigou
Is it OK now? This time I took photo before the bar was just outside the gimbal bearing.
Grub54891
If it slides in with little effort it’s good. Let’s see the entire shaft after you pull it out.
liusigou
Your gimbal bearing is not fixed. The gimbal function is tight on purpose.
Yes. it can turn in any direction. I have aligned the gimbal bearing to the engine. and the alignment of engine has been done yesterday. I have decided to mount the outdrive because the bar moves smoother than yesterday and the witness seems better.
liusigou
Why is the length of left trim different from right side ? I cannot mount it. How can I solve it? I
liusigou
Before the length of left is different from right side. After I tried, the situation got worse, the axis of all parts is not same. So I even could not put rubber bushings in. Have I damaged my power trim? how can I fix it? I thought it should be very easy task, So I did not check the manual.
achris
More fish than mountain goat
No damage done. Just remove the stainless steel pin. Rotate the ends of the rams by 180 degrees. Reinsert the pin...
Chris...
liusigou
Do you mean turn this 180 degres? Thank you Achris
liusigou
I pulled out the two wire connections by accidently at the same time. How can I put it back? these wire are located on the left corner.
liusigou
Why does my engine shake while running even without mounting outdrive? I am sure the engine front has been fixed on the boat. How about the real? I have checked the two bolts at rear cannot be turned any more.
liusigou
It shakes while my starting engine and I am concerned that the shaking will also demanage the coupler.
But it does not shake after I put into forward and the water from exhaust is really very warm.
This time I did the testing without mounting outdrive.
Water is forced into the tube.
Thank you
