Re: can this truck pull it?
I assume you found a plate on your truck that lists 6300 pounds as the GVW. That is NOT the towing capacity. That is the most weight that your truck can carry including its own wieight, passengers, and cargo. You need to find the "trailering capacity" for your truck. This is NOT on a plate anywhere. It may be in your owners manual or available from the dealer. It is determined by your model, engine, transmission, brakes, rear axle ratio, tire size, etc. You MAY find a GVCW rating (gross vehicle COMBINATION weight) this is the most that the COMBINATION of your loaded truck AND TRAILER may weigh. If you find this figure, have your truck weighed as you would normally have it loaded when trailering (including passengers). Subtract this weight from the GVCW figure and that will be the maximum allowable weight for your boat/trailer.
