Re: can this truck pull it?
Fisrt of all, these is not enough info to give an answer to the original question. Short answer, NO.
Long answer: 3 years ago I traded up on the tow vehicle, and bought a Ford Expedition, since the vehicle is my everyday driving car in addition. So, my research (I am an Engineer) is related to the Fords, however, it should apply to any make vehicle.
ford has 3 ways the vehicle is made, regular, tow package and heavy duty tow package.
What you get is: tow package, better suspension, tranny cooler, 4 pin trailer wiring, limited slip axle, but no factory installed hitch, heavy duty battery and bigger alternator.. Tow rating about 6000# with equalizer, 4000 without
H/D package, above plus: larger tranny cooler, power steering cooler, higher numeric axle ratio, must have 5.4 engine, heavier duty tranny, the brake pads are slightly bigger, 4 pin and 7 pin connectors in a bracket welded on the factory 10, 000# hitch tow rating 8900# with equalizer, 5000 without.
Contact any Ford dealer and give them the VIN number. They can access the factorys computer and print out a pick list, showing what standard and optional stuff is on it.
No tranny cooler, or small one? No limited slip? Low numeric axle ratio (less than 3.5/1)?
My Expedition has the factory H/D tow package, and it tows my 7500-8000# boat very well. That's because it was made that way.
Now, add these to an existing vehicle? Limited slip with a different ratio? Probably well over a grand. Tranny cooler? About $250 installed. class IV hitch? about 200 installed.
Find out more about your trucks factory stuff and get back to us.
Just trying to help.
Captharv
