I have a 1989 Force 85HP. I took the lower unit off to replace seals because of leak. I got the lower back on and connected everything back up. Now I have no forward or reverse. I had originally marked the positon of the shift rod before I took the lower unit off but the mark is gone so now I do not have that to go by. I also want to say that I have the model that has a two piece shift rod instead of 1, this rod screws into the lower shift rod. Originally when I first put it back on, the prop would not move at all in either direction, so today I screwed it back down and then unscrewed it to get it up high enough so I could put the pin thur coupler & rod and then put cotter pin on, this at least got it to where the prop would spin freely in both directions, which led me to beleive it was now in neutral and the boat shifter is also in neutral and was when I took the lower unit off. What do I need to do to get it to go in forward and reverse. The manual said that I was supposed to screw the rod all the way down and then back out 4 full turns which I had done before putting the lower back on. This obviously did not work. So what do I need to do, screw it in more or back it out?
