Can't get rid of hijack malware
Mark42
Managed to pick up a Trojan that re-directs the results of yahoo and google searches to their own search engines or select websites. What a pain, but worse, Malware bytes and Spybot can't find it.
Looking for a good hijack/trojan remover. This thing is driving me nuts!
Re: Can't get rid of hijack malware
Ayuh,... Have you searched cnet for it,..??
If there's a good program out there,.. They're reviewed it...
If it's Free,... They've got it....
HopeSheFloats
Good luck with that... I just went thru that a week ago or so, had to wipe the drive and start over. I even used a different pc to download different apps to try to no avail.
Definitely a nasty little bugger...in fact it caused me so much grief that I renewed my subcription to iolo's system mechanic this past weekend. Hopefully someone may know a work-around.
j_martin
open the file C:\WINDOWS\system32\drivers\etc\hosts in notepad.
It may have a bunch of lines of explanation and instruction, each of which starts with a # sign. Those are comments. The only line that doesn't have a # sign should be:
127.0.0.1 localhost
That's called the loopback address.
If there's any other address or url lines that are not marked with a #, then:
restart in safe mode.
Go back to the hosts file and # mark the offending lines.
If it comes back on you, it'll take a Geek attack on the registry to get rid of it.
hope it helps
John
gonefishie
you can't get better if you don't know what exactly is making you sick. There's no such thing as a universal magic pill anymore. I second the hijackthis log post, one in normal mode and one is safemode.
kenmyfam
PC Tools Spyware Doctor has beaten anything we have ever been attacked by.
$29.95 a year but works like a charm. Updates and scans itself when you allow it to.
dlindeblad
I second Spyware Doctor. I had a few bad viruses and could not get rid of them. I used Iolo's software, Adware, Trend Micro house call, and one or two others and could not shake it. After running all of these different programs I then ran Spyware Doctor and it found 300 infected files. The cool thing about Spyware Doctor is that for the $29.95 you get antivirus and I believe firewall too.
Mark42
Have you tried running Trend Micro Housecall?
http://free.antivirus.com/
While on their site you can also dl a copy of HijackThis and post a log here.
I'll run hijackthis and post a log.
Believe it or not, try this:
http://www.microsoft.com/Security_Essentials/
It is actually very good.
Ran that, but it did not find anything. Also ran Microsofts monthy malware program and it found nothing. Uggg.
127.0.0.1 localhost
hope it helps
John
There were pages of entries, all marked as added by Spotbot. I looked at existing backups of the same file in the same folder, and saw they look as you described. So I deleted all entries but the comments and the one address.
Still not having success.
Will run highjackthis, but have to do it this evening. Will post the log.
Thanks for your help! These root-kit malware programs are a pain to remove.
jonesg
I bought spyware doctor, it doesn't work for beans with this new malware.
My computer is completely locked up now.
I ran spyware doctor and it said all was clean, I rebooted and it stays stuck in a boot loop, its says launching windows, then it says logging off.
Can't boot up in safe mode, the machine is dead, I'll have to buy a new computer. :eek:
cribber
The best way to get rid of the malware is to run your system in safe mode and then do full scans with your spyware. Running in Safe mode prevents the malware from loading and tricking your software into think it's an antivirus program. Here is where you can get the MS Security information help and tips.
http://www.microsoft.com/Security/
xxxflhrci
I had a similar experience about a month ago. We got a virus that destroyed my hard drive in about 3 days. I tried fighting it with several different programs, but failed. Right before she locked up, I downloaed the things I wanted off the computer to a flash drive...Then, I went to the local PC store and bought a new hard drive that was twice the size of what I had before for 50 bucks, came home installed it in about 5 minutes and loaded the computer back with my master disks. It took me a couple of hours to get it set back the way I had it before. She now zips along as fast as ever.....I learned my lesson, since I could have lost nearly 10 years worth of pics, and bought a used My Book hard drive off of eBay to save a back up of my pics and other things I don't want to lose.
gonefishie
have you ever consider burning them onto cd or dvd? They aren't vulnerable to virus. Dogs and small childrens are a different story.
NYBo
If you can't get the computer to boot at all, pull out the hard drive, hook it to another computer with a USB adapter, and run a full gamut of scans. Put the drive back and see if it boots.
PiratePast40
Excellent idea.
I've had the same browser hijack malware recently. PC Tools was the only one that found and eradicated the virus. I tried a half dozen others including Microsoft security essentials and malawarebytes with no success. The microsoft product was able to find the virus but it morphed into a different name before it could take action.
It sounds like the success rate for removal is rather spotty - regardless of the product you use. It's really important to catch this one before it gets a chance to initialize, that is, try to run the anti-virus software in safe mode or run from a different OS and drive like recommended above.
jonesg
NAh, drop it in the dumpster. I wouldn't risk putting the infected drive near my business machine.
Whoever writes this stuff needs a beatin, this is as funny as spray painting cars in the street. I suppose its good for the computer business.
