carb and outdrive ratio
MikDee
Banned
Re: carb and outdrive ratio
As I recall, it had a large plate over the manifold where the 2bbl carb sat, that i believe you could remove, & put a small 4bbl on, as long as you found a close match, & adapted the linkage. (I never went that far with it).
bigame64 Didn't I already point this out? I believe you could fit a Quadrajet right on there, and end up with a 180hp/250cu in 6cyl.
starsnstripers
Yes you did Mikdee sorry, I was just looking for some more input on the subject, Thankyou.
Ayuh,....... Just how much More input are you looking for,........
As I read it,..... Your Question has been Well Answered........
Go get a 4bbl. Carb,+ Bolt it On............
DukesFin
I had a GM L6 250 and I had an OMC Log Mainfold and what sat on top of it was Holley 4bbl carb. Large "hole" in the manifold and about a 1" thick adapter plate is what the carb bolted to...
starsnstripers
Thanks guys, thats a positive note. I think it would be a great setup for a 2900 lb SS 215 Slickcraft, with an L6 292 w/4brl in it. Thanks, I'll let you all know how it works when i get it together.
