Carb fuel intake nipple cracked
GlastronMegatron
1986 Johnson 150 Hp 2 stroke
The fuel intake nipple on the bottom of one of my carbs is cracked and leaking fuel on the other two. Looking online I haven’t been able to find a replacement nipple and the float champer assembly is $130. It seems silly to pay that much for such a minute issue. Was curious if anyone else has had this issue or knows how to replace that nipple.1FB0743B-832A-4DD8-99CA-56391D5498F5.jpeg
Honorary Supreme Mariner
If in Canada ----evinrudeparts.ca----Might offer a solution.
Crosbyman
butter it up with JB weld as a temp fix
pre-clean nipple with carb cleaner
check for leaks
Your local hardware store may have brass pipe fittings that will work.---Depends on how much room between carburetors I guess.-----Be an easy fix on my work bench.
oldboat1
You can get nylon or brass 90 degree fittings at most hardware stores -- don't know what the fitting is into the float chamber, though. Do you know where it leaks? (possible it's just a loose clamp, maybe). I see some marks up at the flanges -- if that's a leaking spot, Crosbyman's suggestion would work, I think, with a stainless clamp screwed down over the hose at that spot.
healey8390
Happened to me. Break off the plastic/melt it off. It's presses on to a knurled fitting. Drill and tap to install 90 degree brass fitting. Make sure you get a good seal. I used teflon tape.. I'll try to find what size I had to use.
healey8390
1/8 mnpt 5/16 90 deg elbow is what I used. Will have to drill and tap. Use some sort of sealant for fuel resistant "teflon" type tape to seal threads good.
GlastronMegatron
Thank you all for your help. As an update I was able to find the exact replacement on ebay. After several attempts to press a new one in (I broke 4 of them in the process), I finally got one seated without cracking the plastic. Put everything back together, primed it, and checked. Although it was leaking significantly less than when I started it was still leaking. I have decided to purchase the entire bottom plate that its pressed into.
I tried to find a brass fitting that would work but found no luck. Thanks again.
