huskerdaninva
Thread starter- Joined
- Jun 18, 2009
- 240
I've searched the board and haven't found my info so I'll ask here. Just what can swap with what as far as Force & Chrysler carbs go? I just noticed my top carb on my 1969 70 hp is damaged on the outside of the housing where the adjustment screw is located, making adjustments impossible. The outer lip of the housing is crunched up pretty good. Don't even ask...I had a little issue over the winter!!
What other motors can I use as potential donors? I saw a 1992 Force 50 hp carb for cheap, is that viable it looks visually similar? What about a 105 hp Chrysler set up? I guess, what I want to know is what year, and engines are compatible and any other pertinent info anyone may have? Thanks, I am constantly amazed at the wealth of info and knowledge on this board.
Dan
Dan
