Carb Maintenance?
Knot Waiting
Is there any general maintenance that I should be doing to my carburetor? My engine runs fine and I dont really know jack about tuning carbs (grew up in the age of fuel injection). However, Im a fix it 'before' it fails kinda guy and want to do all I can to avoid any preventable problems. Thanks
88' Mercruiser 350 / Alpha 1(r)
JustJason
Re: Carb Maintenance?
You maintain carbs by making sure you change your fuel filters, sounds basic, but that's really about it.
a70eliminator
It doesn't hurt to spray carb cleaner in and around the air horn and keep the air bleeds clean, keep the linkage lubed up and sprayed down with a rust inhibitor.
Knot Waiting
Sweet. I should be covered then. Never hurts to ask, thanks.
Gary H NC
With carbs if it is running good don't mess with it other than the filters and lube the linkage...;)
betayv
good question there? I just send my to the rebuilder, I forget to change the water/separator,and was running badddddd, just like the others said just keep a eye on the filters.
