Re: Carb needle won't seat - 9.9 - 2001
Be sure you got the right carb kit. You didn't say if it were a 2 or a 4 stroke. With the float bowl of the carb removed, hold the float up so the needle is gently pressed into the seat, blow into the fuel tube. It shouldn't pass air at all. Did you get a new float in the kit? I have heard of the needle sticking closed. those carbs are quite simple. where people get in trouble is dirty and or old gas. There are very small passages that can get pluged up so drain the bowl if you don't plan on using it for a few weeks. The hex screw on the bowl, don't loose the gasket seal on the screw. Running it dry always leaves some fuel in the bowl!!!!!
P.S. The only difference between the 9.9 and the 15 is the carb. on the 4 stroke. Good Luck!!
