maineiac5586
- Joined
- Feb 14, 2009
- 828
SEE ATTACHED PICTURES FOR DETAIL
Actually I have two questions. I am working on the carb on a 1980 Evinrude 35 hp.
1. In the carb I am working on there is no spring connecting the float tab to the fuel valve (see picture). I bought another carb off ebay because I needed the bottom portion of the carb due to the previous owner breaking off the fuel fitting at the carb. This other carb also has no spring. If you look at the carb rebuild kit, the fuel valve has a recess where the included spring goes. Do I need to put that spring on the new fuel valve or run it without the spring? (see picture). Does anyone have a picture to show how the spring is supposed to attach?
2. Question two is related to the third picture showing the brass jet in the middle of the float. It looks like there is a smaller jet sitting inside the bigger jet. Is that supposed to be like that? It looks like it is sitting cockeyed to me. The other carb I got off ebay does not have this second jet inside the big one. The carb from ebay is from a 1979 motor and mine is a 1980. Anyone know if this smaller jet is supposed to be there?
Sorry for the long windness, just trying to get answere here. Thank you
