I am replacing the original carbs on my 1990 90hp Johnson (TJ90TLESB) with the carbs from a 1990 115hp johnson. The "new" carbs have silicone plugs in place of the little brass nipples that are on the "old" carbs. Otherwise, the carbs seem to be exactly the same...
Can I leave the silicone plugs in place and eliminate the the nipples? Or, should I remove the silicone plugs and replace them with the nipples? And in either case, what is the difference between one version and the other?
