hertel11
- Joined
- Jun 9, 2015
- 78
Took off both carbs and replaced gaskets, float, needle valve, and seat. 2005 40hp Johnson model J40PLSOC Engine started right up initially but my muffs didn't fit good (they are new) so I turned off and filled a bucket of water to run in. Once water bucket was filled motor would not start. Did not even sputter or attempt to turn over. I'm pretty sure I cleaned the carbs well and replaced everything just like it was before.. The reason I wanted to clean the carbs is because fuel leaked out the top of my bottom carb previously even when just squeezing the primer bulb. That no longer happens after cleaning them. Now it just won't start or turn over, I ordered new spark plugs but I don't know if that is the issue. Any ideas what it might be or what my next move should be?
