Re: Carbs...Idle...Timing....Am I missing something??
Well the water test went real well, except.... <br /><br />I can't get the idle RPM in gear down to 650 without it dying...It runs real smooth and nice around 750-800, which is where it is currently set. after i got her home i pulled the plugs #1 was almost wet and a little carboned 2 and 3 looked wet and light brown, the best i could describe it was it looked they had pancake syrup spread on them. <br /><br />The motor ran fine at 5800 @ WOT with 350 lbs people 100 Lbs fuel 250 Lbs gear.. my basic load...<br /><br />At Idle the engine smokes alot. and i mean more than i would expect...enough to turn heads...Now i ran 100:1 in the fuel and the VRO is functioning, this is my normal habit for the first tank of the season after that it's strait gas and VRO. But it seems to be excessive amount of smoke even for the extra oil in the fuel. I tried to see how it would react to the choke while at idle in gear...I think the response i got is what i should see...about 1 second with no affect then it dies unless i release the the choke. what do ya think......<br /><br />Thanks Jeff
