Carbs...Idle...Timing....Am I missing something??
kirkland
Re: Carbs...Idle...Timing....Am I missing something??
After reading some i guess i need to get some clear fuel line and see if i'm geting air in the line....where should i put the section of clear??<br /><br />i'm trying to get a portable tank from someone to test.. ordering a new OMC hose and primer all i can find locally is tempo...heard bad things so waiting on OMC to arrive...
Dhadley
With the small portable tank just run a 50:1 mix. Lets plug off the oil side of the pump for now and test on premix. Dont keep squeezing the oil bulb. Once its primed it should never need to be pumped again.
kirkland
I was only squeezing it after i disconnected the oil line at the motor connection just to test all lines for restrictions...all were good....
