carpet replacement
18ft3hull
in a few pics i have seen some boats that have a paint like coating on the floor instead of carpet i have thought about the bedliners kits i see at walmart but they are all black way too hot for the floor but carpet gets nasty what do you guys use ????
BMOLCHANY
Re: carpet replacement
I have seen a few bedliner coatings in different colors at Pep Boys.
zach103
im going with snap in carpet..that way i dont have to worry about rot and i can easily take it out and clean it
18ft3hull
i found a flexible ruber roof paint made for rv's it is white and will make the floor waterproof i think i will give it a try in the spring
Fromtoronto
What is the product name? Also, I have carpet, glued to the fiberglass floor... How will a product like that stick? Clean the floor which is rough somewhat, may be a good idea to keep it rough for non slip.. but how to clean residue from glue to keep the coating sticking?
Anyone try this one yet?
Thanks
fishrdan
Try it on a test area before applying it to the deck. If it's an elastomeric (sp) roof coating it might not be a good choice for the deck since the finished product is rubbery and might not have good abrasion resistance.
I haven't personally used this stuff, but saw it in empty 5 gallon buckets left by a roof contractor. After it dried it was very flexible and soft. We peeled it out of 50 5 gallon buckets with little effort,,, not something I would want to put on a boat deck.
18ft3hull
inside of plastic pail is very smooth not much to stick too but a rough fiberglass boat deck might offer good adhesion qualities especially if cleaned with lacquer thinner first
brc1981
The inside of my old boat looks like somebody had previously painted it with garage floor paint. The type with multi-colored specs on it for texture. Its a base grey color with black, white, and gray stuff sprinkled all over it.
It probably looked good at one time. I'm getting ready to sand it all down and repaint this week. I carpeted the floor and looking to make the sides a solid color.
