Re: Caterpillar Manuals
Our company runs a large mixed fleet of plant and I wonder if you have checked the T/c charge pump for pressure?<br />Its also possible that the shaft seal on the pump may be sucking a little air. Check all the hoses and joints on the suction side of the pump to ensure that all are tight and remove the screen from the bottom of the transmission and make sure it is clean. Even a build up of varnish on the screen can lead to a rise in temp on some CAT models.<br /><br />Good luck,<br /><br />Peter
